10thAnniversary
- Oct 31, 2021
I like the lower setting on ride height, how can I get it to stay in the mode/height when driving over 10mph!?
Thanks fellas
Thanks fellas
I did this on my Grand Cherokee, although I adjusted up not down. I made my own links, but you can buy them fairly cheap, and install is a cake walk.I’m not advocating it, but if you really want to stay at a lower ride height, then look into adjustable links for the air suspension. That will permanently keep your truck lower at all settings (at least, as long as you continue to use the adjustable links).
Hmmm interestingI think there was a workaround posted somewhere.
I’m not sure but it was something like put your truck in entry mode when you turn it off and then remote start and get in and go….. I think it’ll stay in entry but I agree with the others, your riding on the bump stops and that’s not a great idea.
I haven't tried this on my truck on purpose, but it might explain how mine got "stuck" in entry/exit. I lowered the suspension using the fob. Remote started the next time I drove and it stayed in entry/exit until I used the switch to raise it.Hmmm interesting
