Does anyone know what the front and rear wheel travel numbers are for the 2020-22 rebel with the coil spring and I guess the air ride?
I can find the RTI numbers, the clearance numbers, the angle etc… but I can not find wheel travel numbers.
I’ve even found the oem replacement fox shock travel numbers but the rear link makes things a little different and then the front A arm, unless I had the motion ratio…
