Wheel /tire size advice for '21 Limited 1500 w/Air ride No lift
Ram21
Confused on what my choices would be (offset, etc) for swapping out my stock wheels and tires to these Fuel Rebel 6 http://www.fueloffroad.com/wheel/12615/fuel-1-piece-wheels-rebel-6-d679/?finishID=12&lugs=6
in a 20x9 and a slightly bigger tire (295 or 305?). I don't want a 22x9, I like a little more tire showing than tall *** wheels.
I don't want to do a lift or anything. Just want to swap out the anemic looking tires (not crazy about the wheels either) but my have to settle for just the tires for now if I can't determine what would work.
Pic below what I like minus the lift.
Scap
The 295/305 is width in mm.
So are you looking for wider tires?
Scap
The width limits will be published by the tire mfgs. You can pick the tire you like then see the minimum width rim recommended.
Ram21
I'm asking what offset would work with my truck for the wheels, perhaps my question isn't clear. Or in other words what is the stock offset for the Limited 22" wheels, so I can determine the aftermarket wheel offsets.
TechDaddy3x
Arkansas
Well...since that’s my truck your looking at i can offer some first hand advice =). You’re going to want something like a +20 or +18 offset if going 20x9. That will keep it inline with the fender.
a 285/60 would fit just fine
Ram21
Thanks. Your setup looks great, looking to do the same wheels except in black. You don't think a 60 tire will rub?
TechDaddy3x
Arkansas
Nope...most rubbing is cause by offset being negative and pushing the wheels out. My the +20 you wont hit any fender pieces and have clearance of the control arms/struts
louscrw
Warner Robins, Ga
I don’t have pictures yet, damn rain and pollen, but I mounted 295/70r18 Cooper Discoverer AT3 XLT on 18x9 ET0 Icon Rebounds with factory air (no lift or level). I have 0 rub in the 3 days of driving it so far. I’ve turned the wheel to lock both ways going forward and reverse, over speed bumps, and up/down the curb into my driveway (also with the wheel locked).
Reverse
There is a whole thread already for exactly this question
djjr50
I am going to have Michelin Defender LTX installed in 275/50R22 next week (hopefully). It will give me almost 0.7" of total extra sidewall and only 0.4" more narrow.
Hopefully that will give me more tire with the same stock 22" rim (and a better overall tire with more wet traction).
nvbike01
What about in Entry/Exit. It seems that is where most golfs have the problem. I’m also considering trading in my 22s for some 18s.
nvbike01
“Folks” have the problem
louscrw
Warner Robins, Ga
I did lower it to entry/exit mode and turn the wheel lock to lock, I didn’t see it touching anywhere...it is very close though. But, how often are you ever driving in that position? I forget the speed, but it raises almost immediately doesn’t it?
I think I just got the perfect setup, the tire size of this exact tire model (as you know, all tire mfg. are slightly different even if the same stated size) and wheels. I was shocked it didn’t rub. FYI, it’s now been just over a week, and I still haven’t rubbed.
Ram21
Can you post some pics of your setup?
Floyd
How did this turn out??
djjr50
Great! The extra sidewall is great for the ride. Quiet tire and wet traction seems to be good. Biggest improvement is the wheel fills the wheel well better.
Floyd
Good deal. I've seen a lot of talk about 305/45/22
Extra width should be more grippy but also more road feel.
Looks like 275 may be the way for me.
Any handling issues?
