lawlavigne
Been trying to make a choice on this for a while. Looking for something that shines a little bit not too much. More of a matte clean look.
Been using this for the past 6 months after using spray on for years. Don’t think I’ll ever buy a different kind. keeps the wheels from getting overspray and having to wipe down again. Also saves my asphalt from getting “stained”.I've been using chemical guys VRP with an applicator from Amazon
I generally agree with you, especially with the old school aluminum cleaners. New formulations are out there that will protect the outer coating because they are ph neutral and are not too acidic or alkaline. I use the new Eagle One product and it works great on the tire and wheels.I'd advise against using an aluminum cleaner on the wheels. Yes, they are an aluminum alloy. However, they are a painted surface. You should treat them as you would regular paint. After time, the alu cleaner will strip (essentially sand) the clear finish, making them more dull and difficult to keep clean.
It depends on how often you wash the vehicle and what you use to clean the wheels and tires. Using a product like Brake Buster or other quality wheel cleaner (adams/chem guys/whoever else) won't strip the dressing as much as your typical auto parts store cleaners and BB also adds a little bit of corrosion protection to rotors and calipers. Either one is pretty good. If you do a good prep and application the first time its just like any other product just maintenance.@Truckguy which one would you say goes a longer way with how long it last on the tires and till the bottle goes empty?
I would say you get similar length of durability but the VRP has a little more shine imo if you apply heavy. However the Perl can be diluted and used on plastic trim on the inside. Can’t go wrong with either. There’s another product that some posted about I been wanting to try because of its durability and that’s dura-dressing@Truckguy which one would you say goes a longer way with how long it last on the tires and till the bottle goes empty?
I love those wheels. Been looking at those for weeks. You got any full truck pics?I used the Dura Dressing, it takes a good amount of work but it looks great and has lasted for a good month without wearing down.
