APSUB-CH41 is plug and play to add subs/amp. Does require you to pull the screen out but don't have to cut anything. Otherwise you will need a line out converter and have to hack the factory wiring to get a signal.I want to add the JL Stealthbox and amp to the Alpine system in my 21. I want to keep the ANC if possible. Also don't want to mess with the back of the 12". Could really use some help on what's all involved.
Ok Thanks. I'll probably go this route. Hopefully not to big a deal to pull the screen out.APSUB-CH41 is plug and play to add subs/amp. Does require you to pull the screen out but don't have to cut anything. Otherwise you will need a line out converter and have to hack the factory wiring to get a signal.
I believe its 2 screws on top of the dash and then just clips around the edges. If you dont already have some I'd recommend getting some trim removal tools as they come in handy when running wire as well.Ok Thanks. I'll probably go this route. Hopefully not to big a deal to pull the screen out.
Watch the videos on infotainment.com's website. They show how to remove all of the uconnect screens.Ok Thanks. I'll probably go this route. Hopefully not to big a deal to pull the screen out.
