I have a 2018 Ram 1500 Larimie with an 8.4 UCONNECT system. For the most part, the two console USB ports work ok, but they seem to disconnect and switch to radio every time I hit a bump in the road. When this happens, I have to switch back to the USB and the song resumes where it left off. This happened with my 2016 Ram 1500 as well. Is anyone else having these issues? It doesn't seem to matter which thumb drive I use. Any suggestions would be greatly appreciated.
Thank you!
I’d have the dealer take a look, but good luck... If it happens to be working when they look at it, they may not do anything.
I lived with this for over a year, and took it to them several times, but since it was intermittent, and it happened to work every time I took it in, they would not do anything.
The last time I tried, it had not been working for a couple of days, and they finally found the fault. There was a bent connector from the USB hub to the wire harness, which apparently happened at the factory. They straightened the connector, and I haven’t had any more issues in about six months now. It literally drove me nuts, since it would work on and off, sometimes it would work for days, and then it would cut off and not work again for a day or two.
I hope they fix this for you. Cheers,
