TheMadDutchDude
- Mar 1, 2019
Hey guys,
I upgraded my 2019 from the stock halogens to the OEM LEDs and they used to work just fine, albeit the left one would flicker rapidly... the right was fine. This morning, the right came on momentarily when making a right turn and then shut off.
If I am not mistaken, I think it is because the BCM has finally realized that the lights are not using the correct resistance it is programmed for, so it is shutting them off for "safety" ... is that correct?
If so, I've been reading that I need to get an OBD2 programmer. How many of you have done this? Did you buy one from Amazon? I have been looking at this one: https://www.amazon.com/OBDLink-Blue...=1635162953&sprefix=obdlink+mx,aps,126&sr=8-3
Lastly, if that is what I need, how do I get to the OBD2 plug? I believe it's behind the lighting controls (under the wheel), but I'd like to know if that panel is easy to remove rather than trying to fiddle with the cables from underneath. What has been your easier experience?
Many thanks!
Many thanks!
