406mopartech
- Nov 20, 2021
I don't know if this has been discussed before, but I installed the TRX transmission skid plate on my 2019 DT with the Off Road Group. It was a very simple install. I just used the existing transfer case skid plate bolts for the rear of the plate. Then had to drill two 9/16" holes in the front crossmember. Lastly I installed to Riv-nuts in the holes to mount the front of the plate. It fits nicely, with plenty of clearance. It will have to be removed every oil change, to insure that it does not get filled with oil while draining.
