My '21 RAM Rebel has thrown a tranny code and gone into limp mode on a few occasions now: P0733 - Gear 3 Shift Incorrect Ratio.
The issue typically occurs under light(er) throttle input and a 'cold' tranny. When shifting from 3-4 (and 4-5 at times), the RPMs flare up about 600RPM (as if it were in neutral) and then SLAMS into gear.
I found a way to sort of work with it as I need to drive the truck. I need to limit the tranny to 3rd gear when leaving the house. When I get to a faster road, I rev third out to ~3500-4000rpm (where you know it wants to shift to 4th under light throttle). I then back off the throttle all the way, and click the + while it is in slight decel (no throttle input). It throws 4th, and from then on there are no issues letting it shift on its own.
The odd part is, after it slips/bangs 3-4 once, it typically it won't happen again on that drive. It makes me think it is fluid/valve body related, but the level is up to spec (2 dealers have checked).
2nd adder: I also have a 1-3 second delay/slam/thump from D to R, and once R engages it ENGAGES. Truck will lurch/lunge after it thumps into gear. If you throttle too early, it will also free rev and slam.
Wondering if anyone experienced anything similar and if there was a resolution? I am thinking it will require replacement, just dreading the process.
Thanks
Thanks
