TONNEAU FACTORY OUTLET - ONLINE AND MAKING DEALS NOW!
Likes
#2
I'm in the market for a tonneau cover; however, I'm unable to find a way to search for products specific to 2019 Rams on the tonneaufactoryoutlet site? Specifically, looking for tonneau options for a 2019 Ram with Rambox 5'7" bed. Thanks.
Shaun.TFO
5thGenRams Vendor
5thGenRams Vendor
Likes
16
#4
For folding I'd suggest BAK Mx4 and for rolling Retrax pro mx or even the one MX. One is made of polycarbonate while pro is made of aluminum. PM me and I'll get some prices :)
Shaun.TFO
5thGenRams Vendor
5thGenRams Vendor
Likes
16
#7
What's the biggest difference between a roll-up and a trifold??
Folding - you can only fold twice (which gives you about 2/3 of your bed), the 3rd fold leans the cover up against your back window
Rolling - you can lock in just about any position you want as it "locks" into place in multiple locations as it slides back. You lose a bit of the bed for the canister but even then rolling is the way to go if you have a bit more $ to spend.. here are both for you to check out:
https://retrax.com/retraxone-mx
https://retrax.com/retraxpro-mx
https://retrax.com/retrax-vs-competition
https://bakindustries.com/bakflip-mx4
- Shaun
cjmst23
Likes
289
#8
I prefer the mx4 over rx4 for the following reasons :
- the mx4 allows you to open partially where the Rx4 requires fully open or fully closed
- I like the trifold matte finish look better
- mx4 opens fully but covers back window, rx4 takes up 10" of bed near cab when rolled up, but doesn't cover window.... This is a push, personal preference
cjmst23
Likes
289
#9
I'll add that the mx4 8s designed to allow the tailgate to open/close without needing to lift the cover.... Rx4 might work until the rubber wears down, but not designed to work
Likes
8
#11
I prefer the Extang tri-fold because it can be easily removed. There are two large clamps, one per side that can be undone by hand and once its folded you can remove the whole cover in under a minute. Anytime I need full access to my bed I just pop it off. I've even popped it off and thrown it in the bed folded up with whatever oversized thing I was hauling at times.
PaGregSS
Likes
4
#13
I don't see the Extang Solid Fold 2.0 on your site for the 2019 Ram. Could you give me a price for one for a 6'4" bed?
Likes
18
#15
How about the TruXedo Sentry CT?
I will be getting a Rambox with BUG. I like the fact that it uses the bed rails, has no drains and is quickly removable.
I live in MN but I will probably only have the cover fully open a few times a year.
Users Who Are Viewing This Thread (Users: 0, Guests: 1)
