I have a 2020 1500, 4WD, Crew Cab Laramie. OEM tires were Goodyear Wrangler Fortitude HT Highway All-Season Size: 275/65R18 116T. I was not particularly impressed with these tires so I got Michelin Defender LTX M/S Size LT275/65R18 123/120R E. OEM tire pressure recommendations for front and back are 36 psi. Discount Tire said to use 40 psi on the Michelins since they have a larger load range. However, I contacted Michelin directly with all this info and they responded that I should use 50 psi. So does anyone have a similar tire and what pressure do you use?
