Be careful not to mistake that ticking with the evap surge activating and deactivating. Its easily mistaken for a tick.
Its a pump that goes on, and then off, purging gas vapors. Easily heard at idle if you have no tunes on. Even easier to hear if you pop the hood. Its periodic, and depending on temp, and other condirions that affect vapor and fumes, could come on and off every 15 seconds, or every few minutes.
It pumps when ur driving too, but you will never feel or hear it during that.
Easy test would involve a obd scanner, read live data for the evap purge solenoid, it provides a pressure reading. Either 0 or 100 percent pressure. Quick numbers in between while it changes from one to the other, usually.
If those numbers change consistently with when you hear the noise, then its evap.
And normal.
