taller tires
riverinerat
I wish to install 34" + tires on a 2019 Ram Limited air suspension stock truck. Will doing so cause any problems or issues?
Talon4U2NV
Bellevue, NE
Not sure what you're asking. I am on steel suspension, doing +2" up front with coil overs and swapping to an ORP rear spring for a +1" out back. And will run 295/60R20. Sounds like it should clear great with stock wheels and no trimming etc.
riverinerat
I’d put a 2” level
Thanks for the time and coment. With the air ride/suspension I was concerned about issues with rubbing and speeometer and trans. I put LT295/70R-18 with 18/8.5 6-5.5 Crusher wheels on. Big improvement in ride because of side walls going down from 22" wheels.
riverinerat
I’d put a 2” level
Thank you for your time and reply. I didn't want to change any suspension as there seems to not be much involving air ride on these wagons. I ended up not changing any suspension and installing Open Range LT295/70R-18 tires and 18x8.5 Crusher whells. Big improvement on ride because I now have real use side walls as apposed to 22" wheels.
