*Note, I know I should of selected said options before buying, but's what's done is done.
Completely spaced out that LSD/Anti-slip was an option when buying. Gear wise, getting tired of the truck downshifting from 8th when it hits any resistance.
Looking to finally swap gears(3.21 to 3.92) and add the Anti-slip diff to my truck. 2WD model, so no worries about front differential can of worms.
Does anyone know if it's the exact same diff as from the 4th gen Rams, 2011+ models?
What's throwing me off is the articles that talk about a new rear end for the 5th Gens, but not sure if they are referring to the Dana 60 rear axle/the coolant warming up the 2wd rear diff.
If I recall correctly, the standard rear end is 235mm for both the 4th and 5th gen trucks.
And, if anyone has any links to where to buy them from. I know about Moes, just curious if there are any others outside of the dealership.
