Suspension Links
Abrauer
Has anyone used leveling links to keep the trucks air suspension in OR1 at all times? Please advise the brand and your thoughts on the kit and the install process. I just bought this 19 Limited F6983970-05B6-489E-8712-95B29DB3EDC0.png F6983970-05B6-489E-8712-95B29DB3EDC0.png
Jhaney
I have the Revel links. They come set to drop rear and raise the front 3/4”. I turned the fronts down 1 more revolution and it’s level. Ended up raising the front 1.25”. Rides about the same. No error messages. Very easy to install. I used a small end wrench and flat pointed screw driver to seperate the factory links from the sensor and frame ball mounts. Little silicone spray on the new links and pop them on.
