What are the volts reading on the battery?
Checked the voltage for the battery. 12 V before starting the truck up. 11.5 V after starting up the truck.What are the volts reading on the battery?
Normal running voltage usually 14.3- 14.5V.Checked the voltage for the battery. 12 V before starting the truck up. 11.5 V after starting up the truck.
Well, best next step is to take truck to local AutoZone or so and test both, battery and alternator. If both are good then look for loose grounds. I had loose ground once and have done just that to rule out components.Does that mean the battery is the issue? Or the alternator, etc. might be the issue?
Thank you guys very much for helping!!!
