Yedi
- Oct 28, 2018
To start off I have the Alpine stereo. I've always had high end aftermarket systems in all my vehicles. I was pretty impressed with the factory Alpine in my 19' Rebel. Loud, but just not clean enough. I knew this truck needed more Deadening material, and some poly fill in the sub enclosure.
I've attached pics to show exactly what I did. It's alot of work, but pretty easy in general. I applied Deadening to the inside of the trim panels, and the inside of the Door. (Some pics wouldn't upload) and a piece directly behind each 6x9 on the door skin/brace.
Coming from a guy that works in a GM body shop, these trucks are very nice to work on. Removing the door panels is very straight forward.
Removing the back seat is a breeze. Ever take one out of a new GM or Ford? I have.....they are miserable...the Ram is designed much better for ease of taking apart. 18mm and 10mm socket.
All in all, my rattles (more like vibrating plastic) are gone. And the bass is much cleaner. I stuffed the sub enclosure with about half a pillow of Polly fill. Not packing it tight, in my previous experiences this works well. I also put some poly fill between the enclosure and the cab even after putting the Deadening on both surfaces. This got rid of some noise I could still hear while testing. That plastic box flexes alot...
Here is a link to the Deadening I use. An entire box will do what I did.
Kilmat 80 mil 36 sqft Car Sound Deadening Mat, Butyl Automotive Sound Deadener, Audio Noise Insulation and dampening https://www.amazon.com/dp/B0751CBXBT/ref=cm_sw_r_cp_apa_i_50RoCb63QKTQM
Also, keep an eye on the sunroof drains, I accidentally pushed the Right side one out while installing the sub. And noticed my left side was partially out also. EASY fix for something that can cause a huge problem. Reach from the bottom of the truck up .
Hope this helps someone, I've learned alot from this forum and wanted to contribute. Enjoy Guys!
