Airbearmd
- Sep 13, 2019
I just received and successfully installed both the Uconnect Software Upgrade and the 2021 Nav Update. The instructions that come with the multiple USB thumb drives is very intimidating, but must be followed exactly as written!!!
Below is a simplistic breakdown of what you need to do/know;
- Must order for either 8" or 12" Uconnect screen
- Do not confuse the 2 USBs! One is the software update that must be completed 1st, and the second is the Nav update which is completed 2nd
- I had an issue going to the web site to get the activation code, but it was my fault. Enter the URL address exactly as they have it in the manual. It is an http:// address, which most us cut and paste which adds an (s) to the http. That will not go anywhere.
- There is one confusing part that is not well explained in the manual, and that is once you turn the vehicle back on and re-insert the map update USB, the screen does not give you a choice to select UPDATE. Just enter the activation code using the on screen keyboard (Very Clunky). You will see it enter underneath the top code. Be SURE you use caps, space, and dashes- in all of your entries.
- You will need your VIN and Cell Phone to take pictures of some the screens that give versions number etc. unless you have a memory for 16 different numbers.
- The directions for the most part, while complicated, are fairly clear. They could have done a much better job of providing screen shots in the manual. They are very, very hard to see!
- You can save yourself $$$$ by doing this yourself. RAM did a good job with this one!
