Rough Country 2” Level w/ rear n3 shocks
jfred320
I’ve got 33x12.5x20s and they rub a little bit. I know I could trim/mold the plastic away but I also want the look that will come with a level.
I’m looking at getting the Rough Country 2” level kit (loaded struts) and the rear N3 shocks.
Will I need adjustable UCAs up front to correct the alignment?
I don’t want any crazy high lift kit. It’s just 2wd, but I also don’t want to compromise ride quality with a spacer up front.
Is this kit what I’m looking for?
(Link for confirmation
I appreciate any advice, good or bad. F0BD8681-2E1B-465B-A01D-E531EAAECC56.jpeg
Faunce76
You won’t need the arms. They’re needed when you do a lift of 3.5” and up. You can use you factory rear shocks too unless you want to replace them.
