Right blinker on trailer doesn’t work.
gwash11
Hi I have a problem with right blinker not working on trailer. It’s not just the one trailer that has a problem because I tried it with another trailer and the right blinker again didn’t work. Fuse is still good and just replaced trailer tow connector and problem is still there. Any suggestions?
Loudram
South Jersey
Check the connectors for power. The old fashioned 12v light bulb testers are perfect for this. Also check the plug behind the bumper. Make sure that's tight as well. The wiring diagram is on the cover.
silver billet
There are actually two fuses for the blinkers, one for the left and one for the right. I found that out the hard way as well when my right signal didn't work.
Andymax
5thGenRams Supporter
Columbus, OH area
and when it's plugged in to a trailer the truck's turn signal still works. correct? You replaced the F10 fuse in the external fuse box, correct?
