Rear window leaking now what?
Mch5jdm
Michigan
@RamCares
Unfortunately my rear window is leaking. The headliner is drenched and stained. I had work done about a month ago that they had to pull the rear seat because it would not start. I have 32,289 miles on my 2021. I have the fca additional warranty. What do I do now?
Rlaf75
Takes potshots
It doesn't appear the the window frame is cracked which would be the indicator for it leaking. Not saying that it isn't leaking from the window but I would check the brake light and the roof mounted antenna because rhe headliner is getting wet. Since you still have a few miles before the warranty expires I would get it in and get the ball rolling with a warranty claim before it's too late. Edit.... I see the window frame cracks now with my glasses on lol. Anyway, get in and let them fix it
silverWS6
EPTX
Yup, get it to the dealer ASAP.
I had mine leak right around the same mileage as you. I took it in and they checked 3rd light/antenna and determined it was the window. They were unable to replace it due it not being in stock. Window came in and they replaced it, my truck was out of warranty already but they still covered the $1,600 bill from the glass shop.
theblet
Agreed. If it happens to me I’ll have to DIY it. Unless FCA admits that messed up royally, which I doubt they will do
Mch5jdm
Michigan
Im concerned that it will take a few weeks to get into my dealer because they are so booked. Will @RamCares help document it?
Mch5jdm
Michigan
Also how quick does [mention]RamCares [/mention] respond?
Biga
Cincinnati
Could be the third brake light, I've had mine replaced three times over the years but I have not had leaking window yet, nock on wood.
Cbty2050
Really not a complicated process. I would recommend calling or stopping in your servicing dealer and see what that say before asking the internet on how to handle this.
If that doesn't work there is always lawyer up process.
Well, if you contact your dealer with the issue and they schedule an appointment for said issue, then it would be documented
Rlaf75
Takes potshots
Get it to the dealer before the warranty expires and have them document the problem. As long as it's on paper you brought it in before the warranty expires they have to take care of it. Waiting on parts or a service date to get it replaced is out of your hands but it was documented before the warranty expires
cevans6318
South Florida
his last picture shows the frame is cracked.
Mch5jdm
Michigan
Thanks to all for the insights. I’ll stop in tomorrow and let you know.
Derek916
I thought this issue was fixed on 2021 with the updated rear window. I guess not.
theblet
Not sure that the rear window, 3rd brake light, or shark fin were ever redesigned. Maybe someone can tell us
Jako
Borough of Parks
Wasn't the sealant an issue? Original was not up to engineering specs?
3rd brake light and screws were redesigned.
No info on changes to shark fin to my knowledge on 5th gen forum.
