I originally bought the Readylift leveling kit with new upper control arms. I didn't measure but from what I have gathered it really only lifts the front by 1.5" instead of the full 2" so I am thinking about swapping it out. Wanting to go to the Motofab 3" spacer and then also bring up the rear just a little.
I am having trouble finding rear spacers, but it appears that some from the 4th gens will work. Most of what I am finding though is the spacers that go on the bottom of the rear spring instead of the top. How good are these? I have not seen anything except the spacers that go at the top before I started looking.
Ideally, I would only want to raise the rear 1" but the lowest Motofab makes is a 1.5" spacer. If the Readylift spacer really only lifted 1.5" then I figure that would be ok since I would be raising the truck 1.5" all the way around.
Looking at using this - https://rover.ebay.com/rover/0/0/0?mpre=https://www.ebay.com/ulk/itm/161712601517
Thoughts? Anybody here use this type of spacer in the rear?
