Rear Defrost Button
Camper
Kitchener, Ontario, Canada
Can some one, explain to me please, what this button do in the track: 1570913565587.png
According to OM, button should do this:"
Push and release the Rear Defrost Control button to turn on the rear window defroster and the
heated outside mirrors (if equipped). An indicator will illuminate when the rear window defroster
is on. The rear window defroster automatically turns off after ten minutes."""
However, track do not have defrost wires, built into windows. Does it should turn some kind of fan , behind the rear seats?
RebelWraith
Polymath
Montclair, Va.
Can some one, explain to me please, what this button do in the track: View attachment 37685
If you do not have the defrost strips on your rear glass then you do not have the rear defrost function.
J-Cooz
If your truck has the button. It has rear defrost. They wouldn't put it there if it didn't have it.
Damion
If there’s no defrost grid in the rear window but you have a button, it’ll turn on the heated mirrors.
My ‘16 was set up this way
dalailama23
Florida
Mine is the same no rear window defrost but it turns on the heated side mirrors to defrost them. i felt i didn't need the rear window defrost on a truck with mirrors and usually if you have a sliding window it wont defrost anyway.
dalailama23
Florida
Does the part that slides have any defrost capability such as heating strips. i was told it doesn't only the sides so i left it out on my other truck?
VinnyRam
My rear window defrost button came on by itself when I put the truck in reverse. Is this normal ? Outside temp was 45 and no frost on rear window or mirrors.
VaderRebel
Canada
Normal... it's hit'n'miss with the temperature sensitive equipment, but mine comes on pretty consistently once the snow arrives.
The Waco Kid
TX-CO-MT
The rear defrost in my Track powers on with a remote start, regardless or exterior temp or button position at shutdown, or auto climate on/off. Usually. Was annoying....now I just go with it.
