- Jul 2, 2021
Hello 5thGenRams Forum Members!
I am pleased to announce that, thanks to a special partnership with the ReadyLift team, we are able to extend an exclusive group buy for you all!
With no minimum to participate, just send us a PM or email with your vehicle information, and we will send over a quote! These are exclusive Forum discounts that are only offered here at 5thGenRams!
ReadyLIFT was founded back in 2006, producing quality suspension leveling products allowing vehicle owners to install bigger wheels and tires. ReadyLIFT is the most widely known and consequently the most successful manufacturer of leveling, mild, and complete ‘big’ lift kit systems in the market today. By providing quality products designed and manufactured to give the customer exactly what they want without compromising ride or handling quality, the message has been well received. Not only do they provide a quality product, but they stand firmly behind their product with a “No Hassle” product warranty. Simply put, if it breaks, they will give you a new part.
Now, let’s get into the exciting part… The kits!- The 69-1935 SST lift kit provides 3.5" of front lift and 2" of rear lift. The new body style Ram now comes with a composite upper control arm with a sheet metal cover. Our engineers determined the the best kit solution would be to include our DOM tube steel upper control arms with corrected ball joint angles. The lift is delivered by way of CNC-machined billet aluminum top mount strut extensions and spring pre-load spacers. This combination generates a true 3.5" of front lift which is perfect for installing up to a 35" tall tire on a 20x9 inch wheel with a 0 offset. This lift works great without exceeding the CV limits which works well within the OEM tolerances.
The 2019-2022 has a new rear set up which requires an all-new fabricated steel rear coil spring spacer. This spacer provides 2 inches of rear lift and also includes rear bump stop extensions to control compression.
Our 69-1935 3.5" SST Lift Kit will get the job done right and affordably.
Not for use on factory air suspension equipped trucks.
Note: If running a 35x12.50-20, the minimum wheel offset is 0 offset on a 9" wide wheel. If running a 295/65-20 the minimum is a +18 offset to ensure the tire does not rub the control arm at full turn.
Retail: $899.95
- ReadyLIFT® is proud to announce that our long-awaited 6 inch lift kit for the 5th gen 2019-2022 Ram 1500 trucks is now available! After dedicated development and long-term testing, we are now shipping our Ram 1500 Big Lift Kit for the Ram customer seeking unmatched performance, style and durability.
The all-new 44-1960 6" lift kit is a great option for 5th gen Ram 1500 owners who want a great riding tall stance capable of accepting 37" tall tires. Our engineers are delighted with the development of this kit and its many great features that make it the best 6" lift kit on the market!
The 44-1960 lift kit includes many great features like rear Bilstein 5100 shocks, dual-rate rear coil springs, and rear control arm brackets which combine to better capture small bump sensitivity and mid-stroke support. Laser-cut heavy-duty steel front cross members and differential drops retain factory geometry while providing proper differential rotation to ensure there is no drive line vibration when in 4WD or Auto-4HI.
This Ram 1500 6" lift kit adopts all the important elements of a premium lift kit to ensure the truck rides and drives remarkably. Rear track bar bracket, Bilstein rear shocks, longer rear sway bar end links, heavy-duty cast iron knuckles, and even new thick steel skid plates are just a few of the ingredients contributing to an amazing driving experience on up to 37x12.50 tall tires on 9" wide wheels with 0 offset. (See tire details below).
Note: RAM 1500 with factory 22" wheels require a larger bore knuckle assembly due to larger wheel bearing assembly. Vehicles with 22” factory wheels should use #44-1961 – available as well – or install replacement standard wheel bearing assemblies (not included). If installing this kit in any “Off-Road Group Package” equipped truck, ReadyLIFT recommends foregoing the front preload spacer installation - the lifted vehicle will sit about 1/2" front high with the preload spacer installed or 3/8" low without the preload spacer. This kit is NOT compatible with (1) adjustable "air ride" suspension-equipped models or (2) Ram TRX.
Retail $2,249.95
- For those of you who aren't looking to go as extreme, we are passing this deal along to their leveling kits as well
To save on space for additional information on the leveling kits below feel free to reach out anytime
Due to MAP policy, I will not be publically posting the group buy price.
If you have any questions email or PM and we are happy to help!
You can PM us here at or email [email protected] with 5GRam in the subject line!
