ReadyLift 3.5” with 35s
Haroderon
Finally got everything installed and I’m loving it so far. I wanted to keep a manageable size for a daily driver and couldn’t be happier with this set up.
I have no rubbing issues and I haven’t noticed a real loss in power even with the 3.6 Pentastar.
ReadyLift 3.5” SST lift
BFGoodrich K02 35”x12.5 R18
Pro Comp Vertigos R18 Backspacing: 5 Offset: 0
PorBoy
Millville NJ
Looks good, are your wheels 18x9 or 8 ? Also did you use everything that came with that 3.5 lift ?
Chubbs
Looking to do fuel assault 20x9 wheels with 35x12.5 ridge grapplers. Any recommendation on the offset?? They come in +1 or +19. Do not want to trim or have any rub.
Haroderon
I’m running 18x9’s for the wheels and yes I ended up using the whole kit.
I put a few hundred miles on it the past weekend and it’s still as smooth as ever, no squeaks and no rubbing!
Haroderon
I wish I could help but I honestly don’t know what the difference might be running a 20” wheel vs the 18”. Mine have 0 offset and I have no rubbing issues though, but they also have 5” backspacing.
If you haven’t already, check out custom offsets website. I found a ton of different set ups in their gallery on there and they give some details about what they’re currently running and if there was any rubbing/trimming necessary! I’ll drop a link below if you want to check it out.
Jacobbmurphy72
Does your truck have the 3.55 gears? Or the 3.21? Looking to do a similar set up but don’t want to lose a ton of power due to the tires, I also h
does your truck have the 3.55 gears? Wanting to do a similar set up but scared to run 35” tires on the v6, don’t really want to mess with re-gearing due to warranty and all
