Ready Lift 2" Level to 3.5" Lift
whiteram222
I am running into an issue here. I have the 2" Ready Lift leveling kit installed on my 2019 Big Horn. After looking at their site the 3.5" suspension left kit includes the components of the leveling kit plus an additional 1.5" top hat spacer for the front and rear coil spacers with rear bump stop landing pads. Unfortunately Ready Lift only has the 1.5" top hat spacers but wont sell just the rear components. Right now my only solution is to buy the lift kit and re-sell the leveling kit componets on ebay. Before I got this route I wanted to see if anyone out there has ran into this issue and resloved it.
Bustedgrills
I'm running the readylift 2" level kit(upper control arms and top hat spacer) then added bilstein 6112s on the 5th clip setting and icon 1.5" rear lift springs...overall gained 3.5" front & 1.5" rear lift
Wisco417
Onalaska, Wisconsin
Would love to see a pic of this setup. Wanting to go a similar route as I already have the RL Leveling kit as well.
Sugar
I also purchased the 2” kit and will be using 5100s and icon rear springs. Confirmed with readylift that the 2” kit is the same components as the 3.5 SST.
If you want the other rear pieces like the spacer or the bump stop extender, mopar pieces could be used. The parts are in the following attachment items N and D.
Bustedgrills
MadMater'
Where are you located? Anywhere near Maryland? I have a SST kit that I took the control arms from that’s I’d let go cheap.
Milks19Ram
The rear spring spacer was discontinued the last time I tried ordering it.
