RAM TRX Lean Repair For FREE
PotterTRX
Probably a little long winded but it is all the information you wanted and more about taking your truck into the dealership and getting your factory TRX suspension lean repaired under warranty for free due to a new service bulletin.
LaxDfns15
Memphis, TN
Be careful some guys on here will tell you every truck is like that, and it's normal.
Idahoktm
North Idaho
Anybody that can eyeball 1/4" of lean is a special kind of anal...and this is coming from someone that is almost that anal. 1/2"? Yes, that's unacceptable. I wonder if this TRX bulletin will force FCA into issuing a bulletin for the non-TRX trucks that lean?
LaxDfns15
Memphis, TN
Yeah I was more so referring to the other 1500's that lean. It's not normal for a truck to lean with empty to a half tank of gas. Maybe with an absolute full tank you might get 1/4" like Idaho said. It becomes much more apparent when you lift the front end to level it as the wheel well gaps are easier to see differences in.
