copekyle
Just grabbed some new tires for my truck. I successfully reprogrammed the tire size in AlfaObd and now I'm looking to reprogram the TPMS Thresholds. I am using the guide here:
I've got to the part about resetting the RF-Hub and it asks for a pin. Searching around, I can't really tell what this pin is or how to get it. I also saw somewhere that I shouldn't reset the hub without having all the Fobs in the vehicle otherwise they won't work afterwards. Has anyone successfully done this?
Tire Pressure Threshold AlphaOBD.docx
Tire Pressure Threshold Notes Make sure to enable data logging and connect/backup to Google Drive 2018 Trucks need security bypass cable Procedure Key in RUN position Open App Connect to OBD II device Select DODGE RAM 1500 or 2500 or 3...
docs.google.com
