Painting tow hooks?
kingkasc
Hey guys i'm considering adding tow hooks and painting them to match the red lettering.. Opinions on how it'll look and recommendations on what to paint/dip the hooks with? If you have a photo of black hooks installed please post! Thanks everyone.
HeliPilot
Yes on installing the hooks, color is subjective. Its yours, do what you want.
metb4
View attachment 14974 View attachment 14976
Definitely do the red. It'll look killer. I think Plastidip makes a red coating
TwinSac
Reviving an old thread after I searched "Tow Hooks"
I want to do the same thing. Paint the tow hooks red. Plasti-Dip seems likely. Are people removing the hooks or painting them still on the truck?
JasonB
You are going to want to remove them for best job... super easy...
Also consider getting them cerakoted but
Plastic dip will work, just might peel off and need to reapply. Especially if u actually usem
Once
Lize
England
@Jhill painted his Rebel hooks red:
Jhill
Portland, Oregon
Duplicolor makes rattle cans in paint code matching colors. I scuffed tow hooks up with scotch brite pad, then primed with Duplicolor primer, then 2+ coats of color. Let dry well for a couple of days and then reinstall.
TwinSac
I don't love questions like these:
Dupli-Color has a few different shades of red. I'm not matching anything yet so any red would work if I just do tow-hooks red...but I in the future I'd like to red out the RAM in the grill. Any idea what that shade of red would be in Dupli-Color?
Jhill
Portland, Oregon
I used the flame red with PR4 code that matches truck. There are vinyl overlays available that go over R-A-M letters. WWW.ReflectiveConcepts.com has them in most any color, a regular red similar to PR4 flame red and an orange red like GMC colors grill letters. . 5 minutes to install. Well cut for perfect fit on face of letters.
Go24girl
View attachment 33006 View attachment 33007
I cannot get the bolts to budget to remove my hooks for paint. Even the autobody place couldn't get them to move. What did you use? Thanks
mikeru82
The Palouse
I liked the looks of the red tow hooks on the Jeep GC Trailhawk, so I wanted to see how they would look on my truck. I tried plasti-dip but it looked slightly pink with the patriot blue paint. I wasn't trying to color match anything, I just looked for a red that was more on the orange side of the red spectrum. I like how it looks...
TVANVA
Lynchburg, VA
Go24Girl.......
Tow Hook bolts are torqued to 137 ft lbs (front bolt) and 85 ft lbs (back bolt), so you need a big wrench in a very tight spot.
3/4" air impact wrench with an extension and universal joint might do it.
mikeru82
The Palouse
I was having problems using a 3/8 ratchet to loosen them, so I used a 1/2" air impact wrench to remove the bolts.
