Operate power travel trailer jack with dead trailer battery
drhoda
My F150 would power my jack when electronically connected to my travel trailer but my 2019 Ram 1500 will not. Is there a trick to this or am I out of luck?
Dragonmaster13
Find the manual backup crank. Most I can get out of my 7 way connector is 1amp.
cj7
MD
I power my small winch from the 7 way (draws 10-25a, 45a stall) so you should have no problem. I did replace the fuse with a circuit breaker, but wiring is stock.
Bt10
MI
I believe the truck has to be running as well?
