Online Configurator Bug with Bed Utility Group?
BostonBlueRam
If you choose the Bed Utility Group for a Limited Build (only one I tested..) It says I have to select Level 1 Equip Group instead of Advanced Safety Group. As far as I can tell the only difference between the two is the exclusion of the Harmon Kardon speaker and rear ventilated seats. Am I missing something here?
@RamCares you might want to take a look.
ponypride
Level 1 equipment group is not compatible with the advanced safety group. You need the level 2. The BUG should be compatible with both. I would check with your dealer.
glennf14
He’s referring to the Limited, not the Laramie. @BostonBlueRam I have the same question as well.
BostonBlueRam
Yeah I actually tried again without adding level 1 or advanced safety group. But it didn't like that, and wanted me to add the level 1 group before I could move forward with BUG
