Cajuntec
- Apr 25, 2022
So I was due for my 60K transfer case service, and right about that time, my check engine light came on. I got the OBDII test done, and it turns out it was a bad thermostat. Reset it by disconnecting the battery and it was fine for a day before giving me a check engine light again (I always do this to see if the OBDII test changes results). Again - bad thermostat. Basically, it was not allowing the engine to come up to temp. So I added that to the maintenance item when I dropped it off to get the transfer case service done.
They called... my coolant looks like chocolate milk. So I have oil in the coolant. So blown head gasket or leaking oil cooler. They determined it was a leaking oil cooler. So they put in my extended warranty claim and I get back an email saying that it is completely covered, and that I only have a $100 deductible. That's cool.
But today, I get the bill. They are charging me for an oil change and coolant flush / fill. I was under the impression that since this was a warranty job, that those things were covered in the warranty repair. So I pushed back. They are looking into it now.
Am I being unreasonable to assume that an oil flush and change / coolant flush and change would be part of the warranty service, since both were contaminated by the leaking oil cooler? Heck, if I had known I was going to be charged for the change, I would have bought them a couple of gallons of Amsoil and my filters, instead of them charging me for Mopar parts! When she wrote me (I have the email), she wrote, (cut and pasted from the email):
All the best,
Glenn
I GOT EVERYTHING APPROVED MR. GLENN you just have a $100 deductible.
All the best,
Glenn
