OEM brake controller
L.M. Rog
Ok I’ve read several threads here and can’t find a definitive answer to my question. I have a 2020 Ram 1500 Laramie 4x4 with a factory brake controller.
I’ve watched several videos online and see where other trucks have a brake controller in the setting section of the radio display.
My controller shows up on my instrument panel screen but only allows for the gain and is permanently in the light electric brake setting, not allowing me to change it to heavy or any other setting.
Stopped at my local dealer and service writer said that’s just how they work and is the only way it displays and won’t show on my radio display.
So does anyone else have the ability to save and change brake settings on the setting screen of the radio display or is the service writer correct?
Thanks LM
securityguy
North Florida
Thanks LM
Hey bud...just went out to my truck. Select the U Connect apps button. Then on screen 2 is a button "SETTINGS". In settings, scroll to the bottom and you see trailer brake. You can create 4 custom settings there and change all of your parameters to best suit your needs.
L.M. Rog
I’m missing that on mine, that what I tried to explain to the service writer. Looks like I’ll have to make an appointment to get it fixed. Appreciate the help
securityguy
North Florida
I can take a few pics if you like? Do you have the 8.4 or 12" screen? It may have to do with the type of screen you have too but not sure. Happy to help anyway I can my friend!
L.M. Rog
I have the 8.4 inch screen. I’ve seen videos with the standard small display as well as the 12 inch and both are as you described. I’m guessing it needs flashed or something
