OEM 20" tire cold PSI
Grunkster
so I happened to look at my week old Laramie's pressures, and they are set to 43 front, 41 rear...the door sticker shows 36psi cold....is it common for dealers to overinflate or? Just curious, and also thinking the ride would get EVEN BETTER if I let them down to the recommended 36psi! Thoughts?
They usually ship new vehicles with the tires overinflated so they don't flat spot while strapped down, or sitting for weeks in a lot. The dealer should check and adjust them during the pre-delivery service, but many forget to. I know Dodge Challengers call for 30-32 PSI and many owners report seeing 50 PSI or more on their new cars.
my tire sticker reads 39 PSI, i run 40. the dealers dont take the time to properly inflate the tires. most times they are using a cheap barrel tire guage that's been around since the mid '80's.
Did you check the pressure while the tires were cold, or after driving? Once they heat up, the pressures can rise 5lbs. Likewise, the pressure on the door jamb is a MAX cold pressure. I usually inflate 1-2 lbs below the max level because the ride is better.
Cold.... think I will go 34psi... mine were way overinflated
