Nitto Ridge Grappler 35x11.50x20 fit on Stock 20” wheels?
Ram1992
Houston TX
Good evening ,
I need help . I am going to purchase the ridge grapplers tires tomorrow but I need confirmation they will fit on a stock 20”bighorn wheel without rubbing.I have an appointment on Monday to get a 2” level kit installed but I want to have the tires installed prior to the level kit install . I’ve searched the forum but can’t seem to find the answer.
appreciate y’all’s time.
fer1023
Installing the bilstein 5100 along with the mopar UCA(within the next few weeks)
No ORP
Read so much on here I have confused myself
About to order wheels and tires
Prob going 20x10 with -18 offset
Anybody know if the 285/65/20 will fit without rubbing?
Ram1992
Houston TX
No ORP
I also did the same. Read and read, changed my mind a bunch of time till I just went and got my tires installed. I had a bit of rubbing at full turn but since I got my leveling kit installed I don’t rub any more. I’m running stock 20” wheels.
Grey03svt
Will the 12.5 nittos for the stock wheel without rubbing? With a 3.5" Ready lift as well. Or should stick with the 11.5s
Ram1992
Houston TX
Im not sure if you can fit a 12.5 wide tire without rubbing. I attached a picture of the control arm and side of tire on 11.5.
Grey03svt
Wow thats pretty close lol. 11.5 it is! Thanks for the pic!
Ramsgate
Good evening ,
Just got mine done. On very sharp turns I can notice a slight rub that'll go away after a few hundred miles of wear on the tires. Overall I'm pleased with how everything turned out. The other size tire I was looking a is 295/55r20, but it's an inch shorter so I opted for the 60's so the tire size is basically a 34"tall x 11.5"wide.
2019 Ram Laramie 1500 4WD
20x10 Fuel Vandals -18 offset
Nitto Ridge Grapplers (295/60r20)
2" Rough Country Front Level Kit
Rough Country HD2 nerf bars
Ram1992
Houston TX
Looks good! What leveling kit is it? Preload spacer or top hat spacer?
Venom
[/QUOTE
Will a spacer work with this set up stock 20in wheels with the 35x11.5 with level kit?
NJC1684
North Dakota
Nice stance! How far outside the flare is your setup?
Gman1johnson
I’m looking to go with a very similar setup you have. About how much tire do you have sticking out of the fenders?
Chuck19
Southwest Florida
Very nice setup! wish I could get those running boards for the quad cab
Bigdaveincali
SoCal
Those are sick
jkgreene85
I recently inquired about this at a local shop near me who specializes in offroad packages. At first they suggested a 4in lift with 35-12.5-20 but I went and talked to them bc I just put on some 285-60-20 Falken Wildpeaks which they are a good tire for it's purpose but not the look I was hoping for, probably should have went 305 from the beginning, lesson learned. Anyways after looking at my 2018 Ram 1500 crewcab that I have a 2in motofab leveling kit installed, he suggested the 35-11.5-20 due to the factory wheels and with 12.5 there could be rubbing. I also checked tire comparsion and vs what I currently have on there now, the 35 sits a little over an inch higher but with the 11.5 it's not as wide(to prevent rubbing I assume).
Anyways, I plan on going with the Nitto Ridge Grapplers but wanted to see if anyone else had these and how they like them? Again I have the Falken Wildpeaks on mine, to me they are good not great but that's just me lol. So will eventually go from 285-60-20 to the 35-11.5-20 and will look to sell my Wildpeaks as they only have roughly around 3k miles
Appreciate any feedback here!
Thanks!
