New Fox 2.0 Coil-overs
Superman78221
Looks like fox is finally selling the 2”coilovers separate from the mopar lift kit. Fox part #985-02-136 Anyone try these yet? Looks like an easier install than the Bilsteins.
ksn240
These are true adjustable coil overs. The ones in the Mopar kit are just the struts and then you reuse the original spring and other pieces from the assembly. These are a direct swap for the whole factory assembly.
Polo08816
Anyone know what the spring rates are compared to stock suspension?
DeDax
They don't look horribly priced either. I wonder the differences if any between these and the Mopar Fox?
Superman78221
I would think it would perform better since it comes with a spring rated for that specific shock
DeDax
I think I am going to give these a shot. Front/Rear. I already purchased the Mopar UCA's a few weeks ago, so they will be paired with them.
Dookie
Prairieville, La.
These along with 2" tophat spacer on top, with Mopar UCA's and Motofab DR-2R 2" bottom pucks in the rear with Fox 985-24-231's in the rear would make for a really nice and pretty affordable 4" level kit. ~$1,500.00
DeDax
I have the RC Spacer now, gonna use this set up to replace and hopefully improve ride quality a smidge. I figure these should be a little improvement over the Bilsteins which I've had before on other builds while not spending a ton of cash for higher end custom stuff. Ie. Falcon, Icon, Carli, Kings.
DeDax
I purchased these last week along with Mopar UCA's to replace my rough country spacer. Unfortunately the soonest they could squeeze me in for install/alignment was July 23rd. I will review once I have them installed and then again after a little family camping trip in mid august to West Virginia.
Liam Leen
Do you have a picture of the installed?
