Ajvanlaere
Is there any difference between the 2019 classic and 2019 new body front end suspension. I’m trying to buy bilstein 5100 for a 2019 ram 1500 bighorn new body and seem to hit a dead end. Or can anyone recommend front end shocks? I’m currently installing the 3.5” ready lift and had the 8mm and 18mm pass through socket bolt snap and ruin the shock. Thanks In advance.
Reni66
Did it snap after you installed the lift or as the lift was being done?
try this link.
this would mean you have to leave either top hat spacer or preload spacer from the Readylift SST....I think top hat personally.
I am having issues with shock topping out and dont like the preload ride the readylift SST gives.
Ajvanlaere
It snapped while trying to remove the top hat and just made the strut spin. I ended up getting some bilstein b8 5100 24-300872 and used it at the 1/2” setting plus the preloaded spacer and top hat. I haven’t had any problems with it topping out and now run 35x12.5x20 with a 1/4” spacer. No rubbing what so ever
