Need help with electrical issue no interior lights front back sensors including tow no power
Ram909
It seems I’ve lost power to my courtesy inside lights my tow switch front and rear sensors and even the back lighting for radio also the lighting in the 4x4 switch checked the fuses but seen nothing blown any ideas?
RamCares
Michigan
Hi @Ram909 - If you're not able to determine a solution based on suggestions from fellow forum members and you decide to address this with your dealer, please let us know via private message. We would be more than happy to provide you with an additional layer of assistance for that process.
Mark
RamCares
Konrad
Per user's manual: F31 Pink 30A Cartridge Fuse (Mod CBC 1 Interior Light) in the Internal Power Distribution Center, located under the driver's side instrument panel.
Ram909
No luck checked all fuses in the inside panel all looked good looks like I’ll have to go to the dealer
Neurobit
RAM Sorcerer
Texas
Could be the overhead console needs to be reset (a few of us here had that happen).
If you don’t want to wait for dealer to troubleshoot, you can remove it by opening the sunglass storage lid on the console. There are two 8mm nuts you need to remove, then pop it with a trim ply tool (careful to not break tabs etc).
Ram909
Would that cause the whole cluster where the tow buttons and sensors buttons are including 4x4 light button?
Neurobit
RAM Sorcerer
Texas
I never checked that.
For me it reset console lights, pano roof, and remote tailgate opening. Only worked after I unplugged everything, including the plugs in the console themselves, not just console to truck. May be worth a shot. Good luck.
