Hey @rebelman welcome to the forum! How far have you gotten, or what specific panel changes are you concerned about?NEED HELP REMOVING DOOR PANEL IN ORDER TO CHANGE THE MIRRORS. I USE TO HAVE A 4TH GEN BUT NOW WITH MY 19 REBEL THE DOOR PANELS ARE DIFFERENT. NO VIDEOS OR INSTRUCTIONS CAN BE FOUND ANYWHERE... PLEASE HELP
@19RamLimited says he figured it out, maybe he‘ll be along to help you out. Good luck!To remove the door panel is easy though. Three 10mm in total and pull at the bottom.
I cant take credit for these. All the props goes to @ I love grits here on the forums. He has posted a lot of the factory service instructions good dude. Hopefully these might help. @ Jamesfg here on the forums has already pulled the door panels off to add ambient lighting to his rebel so he might be able to shine some light on your issue if you're still stuck as well. Hopefully you have some plastic trim removal tools, if not get some off of Amazon or even Harbor freight usually has a cheap set sitting the shelf.@19RamLimited... the bottom is on really tight..... i wont break any clips by pulling it? cause after removing the three 10mm and its still on pretty snug
Sorry it took so long, They are plastic a bit different than previous as I recall. They do snap back in well.Are the clips metal or plastic?
I'm trying to remove the door panel on a 2019 Dodge Ram 1500 SLT, but I can't locate the trim cover #2 (hiding the two bolts). Is the procedure different for my truck? Any help would be much appreciated - I'm trying to replace a busted driver side mirror.
I'm watching this one carefully. My door lock bezel is not seated and I've tried a million different ways and it wont push further into the door panel to sit flush. Dealer wants to replace the door panel.
Do you got pictures from the front side of the switch? Looks like the wrong part.I know this is an old thread, however I just purchased a set of power folding mirrors for my Bighorn. Originally I had the standard mirrors so therefore it came with a standard window switch and bezel. The guy I purchased the mirrors from did not include the power window switch so I purchased one off eBay from a Mopar part seller. Once received I noticed that the space that the wiring harness fits into is different on the part that I received. Am I suppose to swap out the switch base from my older base and place it on to the power folding attachment or did I totally buy the wrong part? I know this is a lot, but please point me in the right direction. I have attached pics as well for viewing.
The attachment with the pins is the standard switch in which my wiring harness fits into.
The other is how I received the power folding switch.
