Need 2022 TRX Paddle Shift Info...
Jerry Tucker
I modify vehicles for handicapped/disabled drivers.
My customer's hands cannot work the paddles. I need to add separate buttons (not on the steering wheel) to Upshift/Downshift.
I see the signal through the clockspring is a single Brown/Orange wire on Pin-8 at the Steering Column control Module. I am looking for the Upshift/Downshift resistance values.
I do not currently have access to the vehicle to take actual measurements, I want the resistance values to be ready for my customer.
Any help will be greatly appreciated.
Necrosand
Don't have the answer you want, but the center shifter does support push forward/back to change gear up & down. Not sure if that works for your customer but figured I'd throw it out there.
