I was very curious about this, as well. As we all (likely) know, a solid axle car with an open diff (and no traction control) will burn the right rear tire and rarely spin both rear tires in a straight line. I turned the traction control off on my Rebel and simply punched it from a stop sign on dry asphalt. It left two very noticeable black streaks in the rearview mirror while slightly wagging its tail. It made me wonder... First of all, are we sure it's an Eaton brand locker? I believe Auburn once (maybe still?) made a clutch-type LSD that when electrically activated would apply loads of pressure to the clutch disc assembly and it would act similarly to a locker. However, in the rock crawling world these were dismissed because the "locked" diff could be overcome when in a bind, but I digress. I began to wonder what the details are about our E-lockers and how "open" it is when not engaged. Is the rear axle in our trucks an AAM unit? Dana? Something else? I'm not referring to the "max payload" optional axle with the Dana 60 center section.
Thanks!
Tommy
