Mopar power steps rattle
limechallenger
I got a 2020 Rebel and my dealer installed Mopar power steps this last spring. They seem to be pretty solid when I try to move them in the up position ,but driving down the road with michigan potholes and generally bad roads I get a rattle on most bumps. Can't seem to decide if it's the steps or something in the frontor rear suspension. Any ideas?
Not sure this is your issue but:
I had a set installed last winter myself. Back in September I stepped on my passenger sidestep and noticed it was loose. Further investigation I found the front of the board lifted off the hinge, the heads of the screw were broken off. I removed the front cap and slide the block out that the screws were in, removed the broken screws, and reinstalled with new screws.
