Minimum Bora spacer
Qatar
2019 limited 4*4 Air suspension
20 oem wheels.
I plan to order method wheels 18.
I think will not fit with out spacer.
What is the minimum Bora spacer can be fit with out any modification please?
Any advice would be good.
Cross88
Currently CA
If you have the capability/accessibility to remove a wheel, get a measurement of a wheel stud and you'll know for sure the exact minimum length you would need for 0 modification (i.e trimming studs). Also customoffsets.com has a list within there wheel spacer section stating what the "normal" minimum is per manufacturer. But I would personally measure myself to be on the safe side.
Qatar
Thank you
clazer
Like Cross said, measure the stud length but also make sure to measure the pocket depth in the back of the wheel between the bolt holes. That will swallow some of the stud. On my rebel, 1.25” thick fit no problem (pic below). I’m pretty sure 1” would be the minimum. Could probably go to .75” even with trimming only the unthreaded tip on the stud.
