Maxtrac 3” lift
Steelwheelz
CT
Maxtrac came out with a 3” kit with strut spacer only. No pre-load spacer. Anyone think this kit may be a problem with angles and such? Why make this kit?
R
Rob5589
Guest
Yes, it is too much for factory components. Why do it? Because there are people that just want a certain look.
Steelwheelz
CT
If you upgrade the UCA’s do you think that would work and make the 3” acceptable? I mean readylift and RC both have a 3.5” lift but use a preload spacer in the strut. Motofab also offers a 3” top hat I’ll spacer I saw last night. My next option is to go to BDS 4” but that thing is a ton of money plus the time it will take to get that thing in. They claim 10 hrs by a pro. Anyway, my friend has Maxtrac stuff installed on his previous gen ram and it seems really good quality for the money.
Billet1500 4x4
California
Without going in depth into suspension travel/geometry, the gist of the problem with running too tall of a top hat spacer is when the suspension unloads or goes into the position known as full droop it binds up the front CV shafts and puts the tie rods and lower ball joint at bad angles, this is most likely to happen if you're off road and if the truck is in 4 wheel drive actually putting power to the front CV shafts it makes things even worse.
