Hey guys,
so swapped my map bulbs for some led and not sure if I messed up. When I took the bezel off and pulled the part that holds the bulbs the switch for “off, auto, on” popped off too. When I looked it seemed like it might of been molded in the glass along with the little metal diode but I’m not sure. Either way I popped it back in and now the toggle switch doesn’t work. Luckily the lights go on when I open the door and off when I lock the truck but besides that the switch does nothing and I don’t believe the on/off switches work, going to double check in a little.
the research I’ve done seems to point to either bad/broken map light switch, bad fuse, or badly seated cable connection. I’m going to pull it back down and try reseating the cables. I’m worried that I broke the toggle switch since it completely popped off.
anyone have this issue or know if I in fact did break the toggle switch.
-mike
-mike
