Major cleanup on rear door (vomit)
Jlee28
Longtime lurker here with a 2019 6.5 Quad Cab Laramie.
I have a major cleanup job... Someone threw up all over the rear left door. It managed to get into the rear panels, so I'm not sure what to do beyond remove the 3 bolts. I took the car to get detailed but they didn't do a great job, and now the lock indicator doesn't go all the way down (although still functional, just the locked is = to the normal open and the open is twice as tall as the other doors now), so they made things worse.
A little frustrated, and could really use some help.
Scram1500
You need to get that door panel off and get a hose. I'm sure it got into the carpet as well which you're better off replacing. Next time put chucky in the bed
Jlee28
Thanks. Luckily the carpet came out ok, I had some floor protectors on. I can't seem to find any directions on how to pull off the door panel for this generation Ram.
Nails
San Antonio
When you get it all cleaned up. For then he’ll of it. A lot of places are are doing free interior “ozone treatment”. As long as it targets odors too. Worth a try. I did it on wife’s van when one of my little guys let it fly some months back. It worked
Scram1500
It is probably similar to previous gens using a series of pop rivets and one or two screws
sd2134
NV
Front Door panel removal, rear should be similar.
  • Front Door - Door Trim Panel - Removal and Installation.pdf
