Led reverse lights
Cajun_
Louisiana
Have a limited with the fancy led lights all around. Reverse lights suck donkey.
Any have a way to add some of those auxiliary reverse lights in a way that's basically hidden from view?
grimreefer
U.S. Merchant Marine
Free State of Florida
LUYED LED- New (Frugal) LED Reverse Light.
I did the LUYED lights and you would never know they're there until they're lit up. Perfect lighting for backing up at night. There are many different type lights you can use with that setup, though, and it just depends on your preference.
There's also the VLED light above the license plate, but as I understand it, it involves trimming the plate so the tailgate doesn't rub. The tailgate light bars such as the OPT 7 are another option.
Whoa_Ram
Azle TX
I added them as well. Did it a little different, but man they help out a lot!
Whoa_Ram
Azle TX
These are mine. same ones you used, but I cut a small hole in the plastic to have the light shine through.
Whoa_Ram
Azle TX
What lights are these?
Yes same as the link above, I actually used the house it and just glued them to the plastic piece after I drilled a hole in it. I had to angle it a bit so used a piece of plastic but it came out great.
