Many tuners desensatize the knock sensors(only thing I can think of that would be called "noisy sensors"). Which isn't really a good idea, mine were desensatized for a while then after more research I put them back to stock. Turning off torque management improves performance no doubt, but it's there for the longevity of your transmission. Your trans needs the power to be pulled momentarily while shifting. If it don't get this the clutches friction surface takes a beating. But turning it off or down adds like 2 tenths in the 1/4 mile.
I did up the shift pressures though. That's actually good for your trans.
I've been trying to research tuning Mopar and so far the only thing I can really find is that the ECM uses a Neural Network, with is a form of Artificial Intelligence. Pretty cool but daunting to think about tuning.
First, I'll give Justin some credit. His company (Black Bear Performance) has been one of the top GM tuners on the market for at least the last 15 years. And a ride-along tune with a true expert provides far more value (in my opinion) than any canned tune when it comes to getting the most out of your specific vehicle. A self-performed tune is as good as "self", of course
On the sensor issue, IIRC, Justin isolated a couple of frequencies that just didn't make sense and flattened those out. It wasn't so much to change performance as to clean up irrelevant jitter. You could call it "selective desensitivation", I suppose.
As you pointed out, you would never remove all torque management; it's there for a reason. And as I said above, we left some of that in place. The factory was just more conservative than necessary. We did increase the shift pressures; thanks for reminding me of that. I also ran TranSynd in that truck, as I had it left over from my Allison (I called that stuff "liquid rubies"—you'll understand if you've ever bought it). We changed shift points and torque converter lockup speed mainly to force it to lock more often during my commute. I had a lot of 45 mph stretches, but lock was factory-set around 48 mph. We changed it to 42 mph, and it made the truck a much better cruiser between 45-50 mph (i.e. not dropping in and out of lock constantly).
We removed all of the
engine management, since that's basically just throttle response relative to commanded input. It's almost unbelievable that in stock form, you could "floor it", but the computer might not truly command full throttle for
60 seconds or more...that's how conservatively that truck was tuned from the factory. Imagine pulling a heavy trailer uphill, needing to accelerate to get out of a bad situation, etc. Adjusting that to a <1 second delay gave me nearly instant throttle response. Guys on this forum might think of that as having a Pedal Commander combined with a physical throttle linkage...oh boy!
Between this "light" tuning on a factory 6.0L with 4.10s and a custom-routed Magnaflow exhaust (due to Quadrasteer), my '03 GMC really woke up. I wish I had done the same (i.e. a ride-along tune) on my old 8.1L/Allison/4.10 2500HD.
On the Mopar front, I'm a newbie. I don't have any immediate plans to tune this truck, but I'm watching (reading) about others' experiences. If you get into it, please share what you learn!
