I’ve had my Longhorn for 6 months. Couldn’t seem to find or figure out how to turn the headlights off while parked and running.
Finally clued in that they will shut off while the trucks running if the E-brake is applied
It may be the daytime running lights that are on, they use the same lens as the headlamps. You can test this by turning off the daytime running lights in the Unconnect settings unless your truck was built for the Canadain market.
try what you tried already but put the emergency brake on , that will normally turn off the day running light,.. i have not tri<y it yet with my 2022 but was like that in the 2014
This site uses cookies to help personalise content, tailor your experience and to keep you logged in if you register.
By continuing to use this site, you are consenting to our use of cookies.
