Luftmaler
Anybody else not able to setup homelink? I’ve read the threads about weak signal issues , procedure clarifications from manual etc. I’ve followed manual instructions to a T but can’t get the homelink button to learn signal from remote. Nevermind the rolling code issue. Can’t even get to that point. Never had issue programming my 10 and 13 rams on same opener. HL in my new 19 will not learn, doesn’t switch from slow blink to rapid one after clearing and resetting. I’ve tried it with ignition set to ACC, run, on. All with same result...failure. Any pointers?
